G'day there,
As the title says, I'm having problems with the windows on my Vento. Under normal circumstances, I'd just put up with the problems, but I need to gett hem all working properly to finalise a RWC to get the car rego'd in my name. Here are the problems. Passenger side rear, noisy operation. I think it needs some tlc and maybe a new plastic cable guide. Driver's side rear, same problem, but plastic pieces completely broken, so I have had a couple of new ones turned out of aluminium. Should fix that. Passenger side front, perfect! If only they were all like that. The real problem child though is the drivers window. It doesn't do anything. I don't know if its the switch, motor or cables etc.
Can anyone provide a clue or process to check out my wayward window?
