G'day,
Something of an ongoing problem i've had. My VR6 will hesitate/misfire and lose power, sometimes quite violently at exactly 2850-3000rpm, it does it regardless of gear but it is more prominant in the lower gears, and probably 40-50% of the time i go through that rev range.
It annoying the hell out of me, because it will literally feel like i've totally backed off the accelerator for a second, and you can imagine in first gear that'd feel quite violent.
I have had fuel pump issues in the past however since going through 3 of them, before someone finally thought to figure out why. They found out that it was caused by a build up of sediment in the tank from s**t fuel clogging the pump and burning them out. Could this issue still be a cause, could it be fuel pressure issues, injector issues or is it likely something else?
It will pick up again after that, however sometimes it just feels gutless. Comparable to my mates GL! Others its fine.
Coil pack plugs and leads were replaced a few months ago with new parts so there shouldn't be any issues there.
I do have a small vacuum leak in a little pipe at the back of the engine which i haven't gotten around to fixing, however it had the same issue prior to that opening up anyway.
Any help would be great,
Nick
Nick
