Gl running rough as
  • Gl running rough as
    lately ive been having a bit oftrouble with my gl, engine is not holding a steady idle, using too much fuel, flat spotting at different times, i know for a fact its running rich as we plugged it in to a diagnostics tool, but thats all the info it said
    has going to just replace engine temp sensor, but dont know what else it could be
    any help would be appreciated
    Radiators are over rated
    well i replaced the temp sensor, blasted teh crap out of it with some subaru engine head cleaner foam stuff, has gave me my power back no flat spotting etc, altho she still idles rough and no minor backfires.............
    any ideas lol
      Did you change the lambda probe as well?
      Euro Revolution - eurorevolution@live.com.au
      Importing Quality Performance and Spare parts for Audi & Watercooled VW's
      New website almost up and running ... http://eurorevolution.webs.com/index.htm
      Courtney
        i do not know what a lambda probe is lol
          Its just a fancy name for a 02/oxygen sensor
          Polo GTI
          T-Roc R
          Tiguan R
          Tiguan 162 Allspace Wolfsburg
            oh lol thats easy enough to fix its located in the exhaust hey?
              yeah mate
              just before the catalyic converter.
              Polo GTI
              T-Roc R
              Tiguan R
                mightpick up a new one at work tomorow
                it not running quite as rough as it used too, jut seems to use like 10litres per hundred kms
                which is pretty damn bad imo
                  also have a look out for a vacuum leak.. i had a few issues with flat spots , bad mileage and rough idle.
                  turned out to be a combination of both (bad 02 sensor and a vacuum leak)
                  Polo GTI
                  T-Roc R
                  Tiguan R
                    thanks for that bud
                      Probably a vacuum leak.
                      Cheak the plastic pipe that comes from the middle of the engine and goes to the intake and the rubber boor on the top of it.
                        k man il suss it out this arvo and see how it goes
