Hey Guys , I bought a signal + foglight from the US .. they should arrive in a couple of days time .. I've been looking around trying to figure out how to wire the whole thing .. how do you guys recommend i go about it ??
VW BORA 2003 V6 4Motion
Volkswagen Golf MK3 1997 CL 1.8L Rammstien + Autobahn + Volkswagen = Leben !
i bought just an automotive switch from autobarn and made a spot for it in the spare plastic squares next to the a/c button. you'll need enough wire, a switch, relay, and a fuse.
i got a spare set of smoked fog / indicator lights at mine still in box.
Without Your Seatbelt, You Know Your Gonna' Die! Project:mk1 cabriolet 20vt
Do a search, its been covered before. All aussie golfs have the wiring loom already up to the round connector at the radiator support. You just need a euro foglight switch inorder to use the stock wiring and to wire it from this connector.
I am about to cross this bridge...
A question, is the stock euro foglight swith in the headlight switch itself (i used to pull it out one notch for front fogs and two notches for back fogs on my Polo) or is it supposed to be where one of the plastic blanks are?
I just did a search but heaps of stuff came up (it could just be me being a bit computer illiterate)
Help would be appreciated.
Its just a replacement for the standard aussie light switch. Make sure you get one from the UK so its a RHD one other wise it wont fit.
Has the pull out switch to turn on the fogs.
i went under the car and had a look .. couldn't see much cuz it's really hard to get to .. I'm thinking about taking the front bumber down to get it done ..
