can anyone help.......fairly urgent....
    Thank you. Im looking into it too....
      Ive never seen my fan turned once ive turned the ignition off and it has never overheated. I would make sure that it is definately the fans so u dont pay to get it fixed and it ends up being something else.
      A good radiator flush wouldnt hurt, when was the last time it was done?
        i flushed the whole system with degreaser as i had some gunk in there when the oil cooler went on the previous owner. i even tool the radiator out to clean it.
        is there a temperature sender or is that just another name for the fan switch on the radiator....
        going to pick up the car tonight from girlfriends sisters place....and im gonna check it out....
          are you still having issues with the rear window?
          one of mine is jammed up due to the regulator dying, to get the window up, get some pliers and a chamois, place the chamois over the glass to protect it and pull the window up and jam it with some rubber wedges.
          its about $150 or so for a new regulator.
          RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
            Originally posted by Mk3vr6 View Post
            I changed my water pump over the weekend that could be the cause of it!
            Hey MK3
            When you changed your water pump, how did you get the old one out?
            I need to change mine as the seal is leaking but can see what i need to do to remove it
            Everyone is saying drop the motor but how?
            Also do new waterpumps come with the pulley & if not are they difficult to remove
            Mark
              Hey Mark I took mine to Seb at EuroAutomotive and he did it as I didn't have the time and it was quite urgent to get it done. Maybe he can shed some light on it?
                Thanx Steve
                Does it take long?
                Also did he have the pump or you supplied?
                MArk
                  He supplied me with the pump not sure how long it takes but I have been told about 3 hours something like that
