I am worried about another short in the car after my auto shorted out, especially now when I have completed the manual ABF transplant. I have visually check all the internal ori wirings ( doors and terminals K/L/M) while the dash forward are all from the halfcut.
I have disconnected the negative battery terminal and placed a test pen in between the wire connector and the terminal. Opened my vento trunk lid, it glowed very bright, when I closed the lid, the test light went dimmer but it is still glowing and it wont go off unless I reconnect and disconnect the negative terminal.
As for the other door switches and things like head lights/signals, the test light will glow and then completely go off when I switch them off.
I have tried with a separate supply to the trunk light, from fuse box terminal Y, same thing. And as far as i can tell, none of the relays was clicking when I am doing this. I do not have the central locking module nor alarm. I have rechecked the latch switch and the wire running into the trunk lid, they are all ok.
What could be the cause of this?
