Hi all..
I have a 1996 Golf GL 2.0 with Auto. Car has 215000k and is in excellent condition inside and out, and is our second car so it has light duties (trips to train station and the like).
The transmission started playing up a bit so i got it serviced straight away, the mechanic said that it was a little low on fluid and there were some metal filings in the pan, which is obviously not a good sign.
The symptoms of the problem is that when in 1st gear, it doesn't take smoothly and stays in neutral a little bit and revs before taking off. Sometimes it also sort of grabs and hesitates when taking off in 1st. 1st to 2nd it sort of goes into neutral for a split second before finding 2nd gear, after that it is normal. Reverse gear is normal. Symptoms seem to subside once engine has warmed up.
I guess i have some options...
1. Just put up with it until it literally stops going, then worry about it, this is probly an ok option as it is our second car and could handle it being out of action for a little while when it stops going, also i assume by continuing to drive it like this it is not going to affect the engine etc, and wont make the fix any more expensive than it already will be.
2. Get the transmission repaired \ overhauled..
3. Swap in a second hand transmission from a wrecker..
4. Sell the car for parts and buy something else..
I think i am leaning toward option 1, then option 2.
Any feedback on the issue the transmission has, and what option would be best would be appreciated, how much do you think option 2 or 3 would cost me?
thanks
kim
thanks
kim
