Originally posted by thestu
View Post
Thestu's Vento VR6T Build Thread!
no my mates using it...got 6 months rego left.
Reasoning? turbos love gas. higher octane...cheaper than running petrol and worrying about putting 98 in it all the time...its just going to go up in price. i get a $1750 govt rebate. what else can i say it just seems logical!"The Stu likes this"
Re: Thestu's Vento VR6T Build Thread!
And spend twice as much...ecu, loom, injectors and paying to get it mapped properly... Gas sorts it's self out but you can also tune it to what ever you like. I get a 1750 govt rebate and it will be cheaper to run... What more can you want?
Sent from my iPhone using Tapatalk"The Stu likes this"
As much as I'm all for a turbo gas setup & had located & puts some parts aside to do it to my mk1 at one stage, the fueling side is easy to do.
You need to start with a standard GAS install setup, but you'll need a boost reference (modified) B2 gas convertor. You may need 2 of them depending on your planned power output, as one may not be enough.
You'll also need a Gas Research carby/throttle body.
Tuning/getting the right mixtures is the next problem.
Its about getting the right size Throttle body, the right size venturis, metering rods, progressive hose jets etc. spot on.
It may look like a simple system, but you have to know what your up against & what your doing.
Cause a GAS backfire is alot bigger than petrol back fire & can blow your intake clean apart!
Remember. 1L of compressed liquid gas in a bottle is 250L of gas in the atmosphere! YES it is!
I've seen a setup like this power a Falcon into the 9's, so it can make power when tuned right.
But.....
The only thing I think you may have overlooked is you'll still need an ECU (preferably standalone) to control the ignition timing.
Even the mentioned Falcon ran an Autronic ECU & a Crane Fireball Capacitive ignition system to light fire.
I may still have the book here on it too.
I love digging through old threads lol
Ended up getting a mk4 bora and turboing it
Sent from my GT-I9505 using Tapatalk 2"The Stu likes this"
mk3t > mk4 anything1979 Mk1 Golf 2door (Under construction)
still remember when you drove my bora back from foffas... "is this standard?" "its so plush!" lolOriginally posted by thestu View PostI still love Mk3's, but the Mk4 is just that much better to drive.
Hahaha yes. It was lovely lolOriginally posted by dylan8 View Poststill remember when you drove my bora back from foffas... "is this standard?" "its so plush!" lol
