Hi All,
I just noticed a problem with the VR, i have overheating probs and was going to change ther thermostat and the fan switch this weekend. However, on saturday, i took her out for a 20 minute drive and when i got back the temp kept on going up, as soon as i turned the car off the fan kicked in, when i put on the ignition the fan turned off? Would this be a dodgy fan switch or would this be a more complicated electrical problem?
I have been trying all day to get the fan switch off but nothing i use will get it off, ive tried pliers, adjustable spanner, 30mm spanner etc, i even went and spent 25 bucks on a 30mm spanner which looked huge, but even then i cannot get to it. The problem in its in a tight corner and is inset into the radiator housing which is a B******D to get too. I was going to get a socket and ratchet to do the job but the socket is too short and doesnt work either. Has anyone changed theres before and if so what and how on earth did you do it?
Any advice would be great at this moment in time....
