Vibrating Noise
    rims are 1 week old,could have fallen off.swap the rims around and see what happens
      the stick on weights used to balance mags
      often fall off, more so on new rims cause some
      fitters don't clean where the weight is put, like
      you would an older rim
      but bad balance is generaly only at different
      speed ranges eg : 60-80 80-100
      not constant !
      if it is low speeds could be tyre fault
      diffinately move wheel to see if prob follows
      (i'll go and club myself a wife now)
        wheel bearing maybe? because of the spacer there is more of a lever action acting on it?
          Are they new tyres?
          Originally posted by Mk3vr6 View Post
          Hey all dubbers,
          I have a problem with my front left wheel. When the car is in motion it vibrates I have no idea. Me and my dad checked out the wheel on Saturday, thought it might be the adapter but it wasn't. When the car is rolling forward or even going at about 80khm, it still vibrates abit. When I put my foot on the brake it stops making the sound
          I have no idea what it could be, can anyone help me.
          When I took delivery of my Polo the Contis on it made a funny vibrating noise on very smooth tarmac. Salesman said they just needed to wear the nubbly bits off and they'd settle down. They did ... eventually ( @ about 5000k).
          Otherwise ... don't know what to tell you. Previous car (a Toyota) had a shimmy in the steering for the 8 years I had it ... no one could do anything with it - wheel alignments, balancing ... nothing made any difference. At 100kph ... there it was ... right 'til I traded it on the dub ... (and oohh the relief )
          Dave
            Dave
            The Fords actually have that problem, they need to add a shim to the steering. Checked the wheel last night and the adapter bolts 2-3 were lose WTF, anyway my dad used locktight, and today we are taking the car to get the wheel rebalanced and get the front realigned. It needs a alignment.
              Hey all dubbers,
              hahahahahahahahahahahahahahaha........
              very funny !!!!
                very funny !!!!
                Well it was tight on Saturday lol
                  That's probably why adapters are illegal
                  I always use a tension wrench after I have finished working and the car is back on the ground.
                  (But I'm paranoid)
                    (But I'm paranoid)
                    Can't help but love the Porsche rims
                      Be better if they drilled their holes properly!
                        Exactly instead of doing a 5x100 they did something else.
                        tisk, tisk, tisk
                        • #27
                          What do you expect from a company called Fuchsn:
                          • #28
                            they are not redrilled right? standard porsche stud pattern...?
                            • #29
                              Yeha standard.
                              • #30
                                Look what popped up on ebay!!
                                Anyone???
