My airbag light is on permanently and wont go off.
I tried the Battery off for 2 hrs then back on, and it didn't work.
So i have disconnected the 4 pin plug in the dash to switch it off.......
Has anyone had this problem and had to get a mechanic to reset it with the Computer and how much did it cost?
If this light is on, does that mean the airbag will not go off in a crash???? and / or if the indicator light is disconnected will that also effect it due to say some sort of drop in back voltage (i ask this one as the 4 pin connector for the Airbag light has a bit of electronic gear behind it, more than would be needed to just power an indicator light)
Cheers in advance
Cheers in advance
