Noisy front left wheel
  • Noisy front left wheel
    My front left wheel keeps making a high pitched rubbing sound. It speeds up as the car speed increases also.
    Another high pitched rubbing sound also makes itself known when braking. It comes from the front left too.
    What could it be?
    Wheel bearing? I'm definitely not sure but I would attribute any weird sounds coming from a wheel to be the wheel bearing. Did this just started to happen?
    Present: Mk3 Golf variant.
      Could it be the tyre at all?
        stone jamed in the caliper?
          Inner guard plastic rubbing?
          Is the car lowered?
            i got heaps of stones caught in my brake shields when i was in tassie. it doesnt sound high pitched. its a horrible groaning/scraping noise! such a painful thing to listen to. kinda like the scraping nails down a blackboard thing.
            get under there and have a good look for signs of scraping. im thinking wheel bearing as well tho.
            FOLLOW US ON FACEBOOK
              Ok its my day off so I jacked her up and took a squizz underneath.
              I'm no mechanic, but I do believe I have warped brake rotors
              Moving the front left wheel around by hand was rather hard and yes this was with the car out of gear. The wheel would move freely and then catch once every rotation.
              Just to make sure I jacked up the other side and that wheel rotated by hand much better, but still did slow a little.
              Everything else looks fine though, the car is somewhat lowered but not fully sik lowered and I'm only on 16" rims so rubbing guards is out methinks.
              Also I discovered what looks like a meaty front lower swaybar too! No brand name stickers on it but it looks an easy 25mm and painted black.
              So... time to buy some new rotors eh?
                I wouldn't replace them unless the're undersized, just machine them up, save the $$$.
                  anychance of things stuck in some kinda joints or noisy wheel bearing as well??
                  LOL once my car stuck in the rocks, then they got stuck in the brake shield as well!! it made bloody horrible soundn:
                  then everyone just looks at me so I had to stop by and take of both of the front wheels!!!!!at a freezing night!!!
                    It's a bit embarrasing, the noise is much louder to outsiders then it is to me. Thank god the cars got mega dark tint!
                    Going to book it in to a suspension/tire/brake shop I know of, see if they can sort it out.
                      Got teh dub looked at by Wheels World today and they think its a warped brake disc too.
                      They werent willing to be 100% certain, but 99.98% certain. Which is good enough to swap them out for something bettah
                      So, suggestions?
                        ...none??
                          Depends how much you want to spend. You could upgrade to the later model VR6 front brakes that are 288mm where yours would be 280mm. However you would also need the calipers and probably carriers. Easy if you could find a wrecked 97or later model.
                          Otherwise some ATE powerdiscs which I used on the Vento and I was very happy with. When they wore out I tried DBA (Disc Brakes Australia) slotted rotors. They were pretty reasonably priced but they warped after not a lot of use.
                            I checked the DBA catalogue and there wasnt any VR6 slotted ones in there. Am I missing something?
                              they are avaliable im pretty sure, just add SL and SR after the part number
