Ok guys time to do some work.
I need to replace a vr6 gearbox, I have done it many times in mk1s so how much different is the vr6.
1. remove the speed cable and wrapup plug hole
2. i found it easier (with the light mk1) to roll the car along as removing the splined bolt6s for the inner cv with a long extension and a brace.(in out of gear etc)
Pull out cv and wrap. I have the triple square (8mm I think) will this suit the vr6 bolts???
Use stout wire with 2 hooks to hold the shafts up while moving - one hooks onto shaft the other onto top of gutter (above firewall)
3. remove starter
4. remove clutch cable
5 undo the shi**y little 10mm holding the tin on the gear box
6 push the car up onto ramps (like I say they're light)
7 oh yeah the reverse light switch + linkages
8. loosen four bolts atop gearbox and both gearbox mounts mount (just "crack the bolts")
9. crack four??? bolts holding gearbox to engine (long time since last time)
10 jack up box with wood and support with bar cross fenders with wood "spacers" + rope under engine
11. give all a good wiggle to loosen up gearbox
12. undo all bolts except biggies at rop of gearbox near engine
13 rip it out.
now have I forgotten anything????
What major differences with the vr6 apart from being a load heavier.
Thanks.
3. remove starter
13 rip it out.
Thanks.
