urgent problem
  • urgent problem
    ok
    i came up today to malany (sunshine coast) about 200kms from home
    and as i was driving into the car park at a local shop the car started to "surge" like it had a miss but yer sort of felt like a fuel surge and let off some huge backfires and big flames (it normally backfires and flames but these where slightly large and louder than ussually)
    then i parked the car and cam back to it about and hour later & tryed to start it but it just cranks over ( at the very first crank it atemts to fire but then just cranks)
    ive changed ecu's over thinking that might be the problem but no differance
    so i checked to hear if the fuel pump was working when the ignition was on and i couldnt hear anything
    so im qute shore this will be my problem?
    so i got the car towed to my gf's house just up the road (racq quoted me $780 to tow it back to the goldcoast
    and tomorow she will be driving me back down the coast so i can get my other fuel pump
    any other opinions on the problem would be great, figured there might be a more comen problem and dont want to do the journey twice to get parts
    thanks guys.
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Pumps dont just die in my experience. Far more likely to be a relay.
    The pump doesn't run when the ignition is on only when the engine is turning. It should prime before you start it, flick the key on and off a couple of times. See if you hear it then.
    Pull the king lead out of the dissy and make sure you get a good spark off that. Proving the hall sender in the dissy, the ECU and the coil.
    What's your engine code. 2E or AGG maybe?
      Originally posted by chris. View Post
      ok
      thanks guys.
      maybe get a can of aero start or somthing and spray it into the intake see if she'll run on that. (If the spark is all good)
        Try the fuse box mate! I had a similar thing with my car, blew a fuse and wouldnt start, and beforehand it was running like sh*t...
          AAA in yours bud, VR6 joy, on off bang sound like you are getting spark on and off my friend. You can scan that , go back to basics mate, fuel , air and spark at the right time its a goer. If its banging flame then it must be getting fuel mate. Might be G28 having a flip ( Crank sensor)
          Good luck mate
          I got one if you need
          cheers
          Jmac
          Alba European
            thanks for the help guys
            for the first time since ive owned the car im now acctully over it so it will be staying up in the sunshine coast for a while until i could be botherd trailering it down to fix it.
            then hopfully im going to try and put the whole vw thing to the side for a while
            thanks again for the help !
            (]/_ O _____ O _\[)
            "'(O8o)=\X/=(o8O)
            [__|========|__]
              dont just quit on it. it may be a very easy fix, and youll wonder what all the fuss was about
                truer words have seldom been spoken!
                  ignition coil they are $90 trade its def a spark issue. I Have the same engine aaa distrubutor type has been a problem for me before you crank and crank and nothing or it starts and then dies.
                  keep in mind if you keep cranking it you can damage the starter and drain the battery
                    Coil packs will cost more than that william.
                    I`d suspect crank angle sensor first, pretty common on VR6s.
                      Good luck mate
                      cheers
                      Jmac
                      Point exactly
                      Jmac
                      Alba European
                        taking a crank sensor & coil up with me on sat morning
                        and a test light
                        and will have a car trailer ready for the tow if needed
                        & to those that care i have been re inspired with the car ( was just having a **** of a day ) but its all good
                        i will always her !
                        (]/_ O _____ O _\[)
                        "'(O8o)=\X/=(o8O)
                        [__|========|__]
                          Haha it's always up and down mate. I hate my car tonight because the stuff I've been working on is fiddly as shyte, and it's STILL not working properly. I called it quits because I won't wake up for work otherwise!
                          Good luck!
                            Another vote for ignition coil
                            won't get much change from $200
                            sigpicMy NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
