Hey you guys.
Okay, so a week or two ago, I was cruising back from Baccus Marsh doing 100km/h or so, sudden loss of power and stalled, pulled over, wouldn't fire when it was turned over.
Oil spattered on the front left susp. gear, oil smoke coming from accessory side of the engine until the engine cooled itself down, smoke (thin but black oily smoke) coming through the intake, no firing at all, engine will turn, but wont fire up.
I've pulled the covers off the engine, and found that the timing chain is intact.
Turned the crankshaft by hand and the cams turn too, so that hopefully rules out timing chain and/or guides?
My next and most recent theory is coilpack failure, because everything turns fine and it wont fire up, but this doesn't explain the oil everywhere!
I'm an aspiring DIY mechanic, I want to be able to fix this myself if I can.
Help me out pleeeasssee! I'll love you long time. If you're in Geelong and feeling friendly, come give me a hand and I'll buy you a slab or whatever.
Thanks guys.
Jace.
Thanks guys.
Jace.
