Hey guys,
Last weekend I took the car for a good long drive (its been a while) and all of a sudden I looked at my temp guage and it was off the end of the dial (not cool).
Pulled over to let the car cool down, coolant was boiling and spitting out the top of the tank.
Managed to get the car home alright later on after topping the coolant up with water and taking it pretty easy.
When the car gets too hot, the thermos should kick in correct? They were'nt on which was odd as they used to always come on on hot days and never had I seen the temp go over the half way mark....
Car runs fine, but seems to heat up a lot quicker than it used to and if Im driving around long enough, it will go over the half way mark and keep rising.
Thermos still arent coming on (guessing the themostat is stuck or the switch is broken?) and Im a little worried that its getting so hot to quickly.
What else do you think I have broken or damaged? Water pump?
Before I take it to someone else to have a look at, thought I would see what I can get from on here. Willing to change over a few parts if need be, already priced up a replacement pump and thermostat (about $100 delivered from US).
Appreciate any help
(It's a 2.0L 8V btw!)
Appreciate any help
