VR6 brake caliper guide pins - hex Size???
  • VR6 brake caliper guide pins - hex Size???
    Getting frustrated!
    Went to change the pads in the VR6.
    Its a late '96 model so has the Teves ATA calipers.
    Anyone know the size hex driver (allen key) needed to loosen the guide pins?
    Its bigger than a 6mm and smaller than an 8mm (as I found out after putting the wheel back on, heading out to the hardware store and pulling the wheel off again).
    Before I try to find a 7mm key, just wondering if it could be an imperial size??
    7mm allen key bit would be the go on a 3/8 rachet
      I would tip 7mm, I had the same situation in a mk1 srtut tower
      most hardware shops did not carry 7mm, i got lucky at a engineers supply shop
      good luck
        Hard to find a small set with a 7mm allen key let alone by itself. I had to get a complete set to grab a 7mm of my own
        Present: Mk3 Golf variant.
          get an 8 and file it down to fit.
          Or buy a proper 7mm fro snap on or someone
            yep its a 7mm metric
            pads changed
            all is well.
