Power window
  • Power window
    MY MK3 Goes to mechanic tomorrow to find out why drivers side rear window does not work has been a year since it did. have been searching for parts only place cand find new motor is vw dealer ship $600 NO THANKS, I' hoping its just the switch or regulator
    Most likely the regulator on a mk3, they're pieces of poo.
    New ones can be had from the dealer for just over $200 i think, or you could source one from the uk for about $120.
      spoke to my mechanic i need a motor and switch for drivers side rear window so far everybody he has tried wants obscene amounts of money
        Is he 100% sure it's those? Reason I ask is because they can often be misdiagnosed.
        First of all, when you flick the switch to go up or down, can you hear anything at all coming from the window? If you can then both the switch and the motor work. If you can't hear anything, then either the switch, motor, or both won't work.
        If you can hear something, then the best thing to do is to take the door card off the door and actually have a look at the window regulator. If it's broken, you'll most likely find little plastic bits sitting at the bottom of the inside of the door, or you'll find misguided wires, plastic guides that have snapped off the rails, etc. They're stupid, flimsy designs and Volkswagen didn't ever do a recall for metal replacements unfortunately.
          my drivers side is tempermental , it doesnt go down in wet cool weather, but works fine in dry sunny. weird you can hear the motor whine down an up per usual but it just seems like its not catching. funny thing
          ~\\VoLkS//~\\MaN//~
            There are parts available in Australia, at least while people support the locals...
            I always check the wiring inside the rubber tube from the body to the door, the fronts are very prone to breaking.
            It does sound as if your regulator is broken though...
              I Took the car to V A Garage adam said motor seemed to be intermittent he could hear it struggle then cut out no plastic bits found in bottom of door
                That description suggests the regulator has jammed and the motor can't pull the wires anywhere. It's the regulator almost every time mate!
                  i would be listening to Adam at VA Garage if i were you he has had over 10years experience at main dealer VW and Audi both here and in the uk. hope you get it sorted soon
                    I sell the regulators and motors complete for $150.
                    Easier than trying to swop things onto secondhand regulators.
                      WILL CONTACT YOU SOON need drivers side rear and also switch thanks
                        is there a diffference between front and rear electric window motors, karmen replied to my ad im parts wanted says they have one. seems ot think they are the same
                          Yeah they are very different.
                            Motor / regulator and switch are on their way thanks to matt [ golf loon]
