DIY Change HEATER CORE in VW Golf MK3 VR6 with pictures:
So I decided to replace my heater core.
There are a lot of steps involved here but the work isn't difficult.
First disconnect negative or positive or both from batteries.
Remove radio/cd/tape player :
Carefully remove plastics around steering wheel :
Remove lower glowebox :
Remove ashtray and cigarette lighter :
Carefully remove plastic around heater/air-con control :
When you take out there is 3 plastic clips on the top and one at the bottom. You need to remove them to disconnect all cables from switches :
Carefully with screwdriver remove two small plastics parts on the right sine from stereo, and after that unscrew two bolts :
Carefully with screwdriver and fingers remove headlight euro switch and plastics with ABS and airbag lights. Disconnect all cables carefully :
