what turbo manifold for a RHD vr6 ???
  • #16
    ur probably right if u wanna get the same power out of a super charger then ur getting out of a turbo it will cost more but for what ur after 220 at the wheels id suggest u find urself a t28 ballbearing turbo, boost controller, gtr front mount, waste gate, BOV, just remap the computer and heavy duty injectors ( ur obviously gonna need custom manifold dum pipe and exhaust) but ull easily get 220 at the treads running 1 bar and ul spend around 2g'z on the parts and im not sure how much on istallments and the manifold and all the way through exhaust but doubt it will b more then 5-6 g'z and ull make over 220 ( my dad spent around 5 and his making 200 at the wheels on his soarer) hope that helped
    • #17
      Originally posted by Tim
      make less power and higher in the rev range.
      You can set them to run when ever you want can't you?
      • #18
        with super chargers because there run of the belt (unlike turbo's hit on boost hard at about 3 and stay on till red line) the superchargers get higher boost the faster the belt spins and depending on the pulley ratio
        • #19
          That would only be true assuming you have a high displacement supercharger which requires a comparatively greater effort to reach max boost.
          It all depends on what application/size you look for but if your not gonna run more than 8psi, theres no reason why a smallish supercharger cannot make that same power for the same cost possibly even cheaper.
          • #20
            true. its all in the pullies and strings really
            FOLLOW US ON FACEBOOK
            • #21
              I reckon the VR6 is laggy enough already I`d go supercharger for more low down power. The VR6 has heaps up top already.
              • #22
                i thought the SC robs u of low down power cos you have the extra friction but no boost yet.
                A turbo setup doesnt have to be laggy. we are talking about a 2.8L engine. Ud think it would be capable of spooling up a modest turbo without much trouble.
                • #23
                  think about which one is easier and more cost effective to fit, i would go supercharger as better down low more torque where needed which is low revs, they already have kits set up in the states for about $3000 american thats injectors ecu supercharger and everything needed by the time you get a decent turbo manifold done you could have fitted a sc kit
                  • #24
                    Not been in a G60 ever, my Golf would pull from 1000 revs in top no probs. A very flexible drive indeed.
                    No high revving BS there. Yeah the charger takes a bit of turning but the torque from practically no revs is addictive.
                    • #25
                      I`d go SC in your car too William. It`d fit nicely down there on the RHS too
                      There is a French mob who make a nice bolt on job, but big $$.
                      • #26
                        im open to offers of going for a spin in one!
                        The SPA Turbo manifold can be had for under $500AUD landed
                        A VF or C2 SC kit from the states will cost well over 5k AUD landed. Altho C2 dont have decent software for our ECUs yet. It is something they are apparently working on last time i emailed chris tho.
                        The VF kit apparently aint all that good tho.
                        • #27
                          [QUOTE=Tim]im open to offers of going for a spin in one!
                          You'll have to speak to Carpoid, G60JAY or Aussieg60, I left mine in the UK.
                          The noise they make rocks.
                          I have been in a supercharged Golf VR6 as well, would have wupped teh G60 with about 275HP and no intercooler!!
                          • #28
                            nice!
                            Gotta love the supercharger whine. plastics supercharged R32 sounds pretty mean.
                            getting back to the original topic of which turbo manifolds will work on a RHD. The EIP one has been used on quite a few RHD cars in the UK. But apparently its a close fit depending on the size of your turbo. Altho being a tubular manifold i guess it would be easy to modify if you need to. But then if youre gonna do that u might as well fab something from scratch the design of theirs is pretty straight forward
                            • #29
                              i hear what your saying but personally i would prefer a supercharger over a turbocharger more room in a vr6 for a sc better cooling where is located easier to mount no oil lines, vacumm lines, turbo timer,pipeing majorly
                              • #30
                                superchargers still run oil lines
                                This argument has been done to death
                                One factor to also consider is heat . A turbo will generate a lot of heat .
                                A turbo is probably more efficient but for the power you guys are after a supercharger is the most cost effective way of getting that power . And I agree with Tim 300hp + in a fwd = wheelspin
                                As for the manifold , they can be made here , I'll find out what the will cost but what kind of application will it be needed for ? There are soooo many different turbo's out there . First step is to work out what turbo your gonna use !
