I wanted to check with you guys and compare idles for the 1995 vr6's, i have no problem with it just wanted to clarify.....
When i do an absolute cold start .. it will jump up to 1,100 - 1,200 rpm for about 30 - 40 seconds... then will drop to 800 - 900 in the next 2 - 3 min and eventually when it's warm enough it goes down to 650 rpm... Is this the normal idle???
I have installed a 5.5 lb fidanza flywheel and a BMC panel filter ... it has still stayed the same idle process which i have no problem with...
Also about the throttle - when i hold it down a tiny bit and keep it constant the revs go up slowly from 650 to about 1050... And it plays around that 1000 rpm mark.. It's like its unstable ... I haven't changed the spark plugs and leads since i have gotten the car which i am doing very soon....
Any help appreciated.
Thanks,
Boki
Thanks,
Boki
