Mk3 VR6 Electronic issue
  • Mk3 VR6 Electronic issue
    Hey Fellas
    Im new to this site, so i apologize in advance if i have posted this in the wrong section, anyway the problem is as follows:
    The battery died a short time ago + the vr6 hasn't been run for some time now, anyway.. i believe my brother tried jump starting it with a portable jump starter, however i think he placed positive on positive and negative on negative instead of earthing/grounding the black. I hear that this can cause a surge of some kind which can effect the computer.
    The golf will start up with another battery however it will cut off/ almost straight away once the engine fires, even if i "rev" it
    If im right about the computer issue, is there anyway which i can get my hands on a aftermarket/second hand computer? and for how much?
    "1996 Mk3 Vr6 Golf"
    Any help would be greatly appreciated
    Cheers Matt
    I`d say its the immobilizer cutting in. You are probably using the wrong key or have lost the chip out of the key.
      aw i think i have used both the origonal and spare key. I have also tryed starting the car with the alarm on and off.
      im not sure what it is but I hope your right
        Factory immobilizer.
        If you have some aftermarket rubbish attached to the car, particularly if it is a repeller alarm, I`d cut it out and put the wiring back to stock. 90% of the time that fixes the problem.
          Cheers for your help
          As far as i know its the standard factory alarm
          Anyway i will update it as soon as i grab a new battery and see how that goes.
          fingers crossed
          Cheers Matt
