Hi everyone - I'm new to the forum!
I've got a '96 Golf VR6 (manual) which I bought in January.
Its a great little car, aside from a nagging problem I was wondering you might be able to offer some advice about.. The problem relates to the drivetrain (I think). Its a difficult problem to describe - I'll do my best..
The car makes a jolting 'thud' when the car goes from coasting (in gear and moving but without the accelerator pressed) to power.
When the car is under acceleration, there is no problem.
However when I go from coasting (no accelerator applied) to applying the accelerator, there is that jolting thud as the engine takes up the momentum.
So for example, if I'm cruising at 80km/h and go down a gentle hill, I lift the accelerator (so I'm not going too fast) and the car JOLTS as the momentum goes from the engine pulling the car to it coasting along under its own momentum. Then when the speed decreases and I want to re-apply power, the car JOLTS again as the engine takes up the power.
Also, when the aircon is on, if the compressor kicks in and takes some of the power from the engine, there is the same thud as the momentum of the car shifts from the engine pulling the car to the car coasting along.
Of course it thuds again when the accelerator is pressed to compensate and the engine starts pulling the car again.
I've had a friend who has more mechanical understanding that I have a drive and it puzzled him - this problem occurs in all gears, leading him to think it is a problem with the gearbox main drive gear.
Its a wierd problem especially because its a manual car!
VW V!illage thought it was an engine mount problem and replaced the rear engine mount. But this made no difference.
Any ideas what this might be???
I'm located in Sydney's east and I'm having a tough time finding a mechanic with some good knowledge who won't charge me a bucket just to look at it and try diagnose the problem.. Any suggestions where to take it? Barl0world VW seemed too expensive to me.
Any advice you could offer would be muchly appreciated!
Attached is pic of the lovely (aside from this problem) beast.
Thanks!
G-man
Thanks!
G-man
