how much for a vr6 engine
  • how much for a vr6 engine
    yes how much as i might have bent valves and just woundering what would work out cheaper to replace valaves and chains and etc... or just buy a second hand vr6 engine
    Generally cheaper to replace the engine. No idea on cost tho, sorry.
      The engine in my car was replaced due the previous owner smacking the sump, thus bending the oil pickup, severe engine damage etc
      I actually have the receipt; from Brooky Parts it cost $1650 for an engine with 65000km on it.
      Mark
      Mark
        Try CAMDEN GTI PERFORMANCE I was bought engine 5 days ago for VR6
          yea good question.
          I just come back from nz to have my chains become loose and bend my exhaust valves in my VR
          ive been tossing up where to get a second motor or just parts. Parts alone are gonan be $1000
          2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
          1986 SAAB 900 Turbo 16 S
            just had a vr engine put in a second golf vr6 last week! the engine cost me $1000 without throttle body , put new water pumps on ect $1800 hundred all up fitted, the engine was from a half cut from japan with 80 000 klm on it , it truly sounds sick , lowerd on bilstein and konis all round , will put some pics on photo bucket soon ......by the way it was lordcrumbs vr that i bought for $1800 ...
              Damn dude thats pretty good!
                thinking im getting a bit too silly on the spending , but its all over now, the only problem im not sure wich vr to drive !!!!!!
                  If it was me i am a vr6 owner myself id reco the head doesn't cost all that much its like $6 a valve only have 12 labor is the killer in any job go new everything head gasket, valves, valve steam seals and id look at a bit of port work and a 3 way angle grind on the valves, vr6 heads are known for poor flow then you have piece of mind its all new and bit extra performance and while the head is off they can check bores for marks and piston slap at least you will know your engine
                  Facebook Mk1 Golf AUS
                    yeah you can prob have the head rebuild for under 1000, another motor with over 150k's will still need the chains done anyway.
                    cheers brenton
                    MK1 4door
                    MK2VR6
                    MK3VR6
                    Transporter
                    1st place, stock MK3VR6. Vw nationals 07
                    2nd place, mod MK2VR6. Vw nationals 09
                    and untold wrecks
