do i need to use 'VW' branded coolant on my vr6 or does any off the shelf product work and compatible with the original coolant?
advice: what coolant to use
yeah i used g12+ or g12 ++ which ever one make sure u use the same type and dont mix them , so this may mean u have to flush your system, so u have to dc the lower radiator pipe and run the motor while adding fresh water or dist'd water, till the water coming out is clear. so u dont get any of the old coolant staying in the bottom of the motor, unless of course u are useing the same type. then u just top it up.
i used dist'd water and the g12++(or maybe it was only 1 plus) and i saw a reduction in running temp over store noloan and tap water.
hope this makes sense
cheers brentonMK1 4door
MK2VR6
MK3VR6
Transporter
1st place, stock MK3VR6. Vw nationals 07
2nd place, mod MK2VR6. Vw nationals 09
and untold wrecks
Firstly Sorry that I am asking another question here without helping and knowing the answer for the question... I have seen heaps and heaps of the Golfs with the G12+, which is kinda pink & red, but when I bought my car back, its having those dark blue coolants mixture in it... does anybody knows what are those?? and whats its mean 'dc the lower radiator pipe'?
Carlson
Originally posted by SOHCand whats its mean 'dc the lower radiator pipe'?
And dc just means DISCONNECT the lower radiator pipe...
Dark blue coolant is normally G11 coolant which VW fitted up till about 1996. There is usually a notice near the coolant tank which states what coolant was fitted, ie. G11 or G12.Par 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
yeah just remember not to mix the 2, g11 and g12 because the react and make a slimy goo i was told. not what u want in your cooling system
MK2VR6
MK3VR6
Transporter
and untold wrecks
VW G12 Plus
Get the G12 Plus - it's a fluro pink kind of colour.
G12 Plus was developed to solve the problem of G11 in older cars and G12 in newer cars turning into brown goo when they're mixed. G12 Plus is compatible with both G11 and G12.
In the VR6 There's a drain plug on the plastic downpipe in front of the radiator - do a search for "crack pipe" as this is what the pipe likes to do =) and you should find some diagrams.
More info on it here:
VW say it's good to be filled-for-life, so it shouldn't need flushing and replacing, unless you're doing work that involves the cooling system.
Which brings up the topic, whats "life". I wonder what they mean.
Mk1 Golfs gearboxes were filled for lifePar 6 Golf GTI. Coilovers, BBS CH Wheels, APR'd
Originally posted by gtimk5Which brings up the topic, whats "life". I wonder what they mean.
Mk1 Golfs gearboxes were filled for lifesigpic Camden GTI Performance. VW / AUDI Specialists
Filled for Life
With the filled for life, it means that there's no set schedule to replace the coolant. If it's looking murky, or you need to do work on any part of the coolant system, then that's a good reason to change it, but if it's all looking good, with no rust or other crap in it, then there's no real reason to drain it and change it over...
