ah Crap we can't get Wilwoods :(
  • ah Crap we can't get Wilwoods :(
    Dag nammit,
    they dont have dust seals! ah crap I am 50/50 on these there great value however I dont know if I can get through engineering.
    any thoughts
    90 GTI Mk2 1.8t soon to be with GT28rs
    Go oem. You staying 4 stud go 280
      OEM calipers are better than Wilwoods anyway
        Oem huh, as in the girlings? I managed to source a 22mm master cyl. as well so im set i just need some nice brakes. Yer im after 280mm corrado discs and then some form of caliper
          I have a strong feeling that willwoods won't make the grade for road use here
          Girling 60's twin pots are the go with a 24-25mm master cylinder
            Hey Valver, I am curious, what is wrong with Wilwoods (beside the dust seals). I know you have referred to them as 'show' brakes, is that due to maintenance or performance issues?
              dont ofrget the SEAT Cupra 16V disks and calipers are 280mm and bolt on aswell
              '98 Mk3 Cabriolet 2.0 8V
              '99 A4 Quattro 1.8T
                Yeah I have a set of the cupra carriers and calipers Tommy. You could keep it 4 stud and still have awesome brakes.
                  ah so many choices! i have a 22 mm master cyl so thats a start!
                  Willwoods are a no go now
                  ECS porsche brakes won't fit under my 15'' BBS
                  AP racing won't either
                  so that leaves me with the G60 or Ibiza Cupra brakes, I thought these where brembo 4 pots that ran a 12.3 inch disc ? or is that just the Cupra R ? Which again would not fit under a 15'' wheel or am i wrong?
                    A 22mm master cylinder will improve your pedal feel to start with
                    You can the put on the mk3 hubs with the 256mm rotor which will take the cupra or girling 60 carrier/calliper if you are still not happy with the 256mm
                    There are all sorts of rotors & pads for the 256mm brakes, which should give you heaps more stop than standard
                      Ive got the Ibiza Cupra R brakes and they wont fit under 15" wheels. They are 305x28mm 4 pot and will need 16" ± spacers.
                        Yer thought they wouldnt fit (cupra r), yer the mk2 8v hubs won't work as we all know! so the early mk3 4 stub hubs will do as we didnt get the later 16v hubs here.
                        any how i think ill get a nice 280 mm set up
                          rayray is selling a set of mk3 gl hubs that come off a 95 model which may be of use to u. bbm, fourseasons and ecs sell the girling60 caliper kit if ur going down that route.
