Wouldn't a hole drilled through the floor lead to rust anyway?
mk2 swimming pool
Originally posted by Satanstoenail View PostWouldn't a hole drilled through the floor lead to rust anyway?
if you just drill it and leave the bare metal there, then yea, it'll rust.
a rubber bung of sorts might help too.
Originally posted by carpoid View Post... the membrane behind the door driver door card, the water used to run down into the window slot, then come out of the bottom of the door card, then get under the carpet because the membrane was rotten and had holes in it.
Make sure there's no water on the front floors too. From the front floors, water can make its way to the back floors. If there's water in the front too, then that's almost certainly how you're getting water in the back. Water in the front could come from a leaking heater matrix, leaking heater hose, leaking air boxes.
and even no plastic cover on the rain tray then down into the heater and onto the floor . you really have to catch the water in the act, but drilling a hole in the floor doesnt fix the problem lol then you will just get a river instead of a pool. but everthing still gets wet when the water comes in.
cheers brentonMK1 4door
MK2VR6
MK3VR6
Transporter
1st place, stock MK3VR6. Vw nationals 07
2nd place, mod MK2VR6. Vw nationals 09
and untold wrecks
