Looking to upgrade my brakes sometime in the near future. Currently have the seat cupra brakes. I've seen a few options, willwood kit, seat Leon cupra r Brembos. Just trying to find the easiest and best option. I'd like to be able to keep my 15s but would also go 16s. Let me know your suggestions.
Brake upgrade options
So are you running the 280mm front disc setup?
Why do you want to go bigger?
I run the 280 discs with golf 3 GL front hubs and the VR6 callipers. Standard mk2 GTI rear. Just using Ate discs (the best) and EBC greenstuff pads.
I've done a few track events with this setup under my 1.8T and found it was more than adequate. They were pushed pretty hard too....
Cheers,
Wade-1990 Mk2 GTI 5-door with AMK 20vt (260hp @ wheels)
Yeah running the 280mm, I'm thinking if going gt28 or something like that and I'd like to upgrade the brakes. Was thinking of trying to get some 4pot brembos and keep current disc size( would need to get adapters made). There are lots of brakes I can use but it's extremely hard to find them in aus, so I'm just trying to find out what people think is best and worthwhile .Originally posted by GOLFBALLS View PostSo are you running the 280mm front disc setup?
Cheers,
Wade91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
02' Audi S3 (soon to be gtx3076’d)
The 6 pot Tarox brakes are working well for me.
I'm running the 280mm disc inside 15" rims.
(I've got them on a MK1, but it's using MK2 16v uprights.)
I gave up on he stock style single and dual piston calipers as I kept getting pad knock off no matter what I tried. Now pedal feel is consistent through out a race.
Just watch out for clearance on the back side of the wheel with any of the big brake kits. It can be hard to find wheels that will clear the calipers.
Tarox | High Performance Brakes79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
They look to be good brakes, but are a little pricey. I was looking at trying to get a used set of brembos or something like the 944 turbo brakes. I hear they bolt up with a spacer for the brakes, not sure if you use front or rear brakes though... Willwoods seem pretty well priced, anyone know anything about them?Originally posted by Peter Jones View PostThe 6 pot Tarox brakes are working well for me.
Tarox | High Performance Brakes91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
Reckon a stock rebuilt mk3 4 wheel disk setup will stop this car fine,if its all new or reconditoned it will do fine with good pads,these cars are pretty light afterall.sigpic1987 Golf GLI Wolfsburg Edition,full gti spec 3a Audi 2 litre on dijifant 2
1989 Corrado 1.8 16v KR manual (02a) black 15x7 RH cups
1987 Golf GTI original 3 owner in white.
Audi Quattro,and various Porsches
Tarox are fairly well pricedOriginally posted by Schalke04 View PostThey look to be good brakes, but are a little pricey. I was looking at trying to get a used set of brembos or something like the 944 turbo brakes. I hear they bolt up with a spacer for the brakes, not sure if you use front or rear brakes though... Willwoods seem pretty well priced, anyone know anything about them?
Willwood are the cheapest BBK kits out there (not by much) - not really sure why they are cheap - the only thing I've heard is they don't have dust seals (they are more for motorsport) and this can cause problems
Have a look at the price of KSport/StopTech/Brembo (new) and then compare to Tarox
Or buy 15 year old Brembo's (especially if they have been sitting at a wrecker for years) and after paying to powercoat, re-kit and tap out the bleed nipples (it can be a frustrating nightmare) and then compare to Tarox2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
There are many brembos on newer small cars that would be running discs around the same size... Wouldn't have to be super old, or I could buy a reconditioned set. The reason I want to go different brakes is the single piston doesn't seem to work as good as I'd like it to. 4 pots apply the pressure even and that should make for much better braking. I may look around and try find a set of brembos and get a brake carrier made. Just trying to find out if anyone knows of any that could fit easy.91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
Ok
Single piston calipers do apply even pressure to both pads, provided they are floating well.
Multiple pot calipers apply pressure over a wider area of the brake pad
Have the rotors machined and use some pads with more bite - like Ferodo DS2500 - that makes a noticeable improvement
Not many small cars have Brembo calipers
The Nissan 350Z has small two pot Bremobo's at the rear (running on a 332mm rotor) - but they tend to cost $600 from a wrecker
Most adapter plates are for calipers with radial mounting bolts (not OEM Brembo's with side mounting bolts)
You can get Seat Ibiza Cupra Brembos for 600 GBP and the adapters for 129 GBP - that's $1350 AUD but postage will be another $250 easy
You can also use front Porche 996/Boxter calipers, they cost about $800 AUD and the adapters cost $220 AUD
You need to obtain Seat Ibiza Cupra rotors, 305mm * 28mm to make this work
(there are probably after market rotor options available)
Pretty much any way you go BBK's are pricey so you need to be determined/committed
BBK's are awesome however
I have a HPA BBK on my Skoda Octavia and a Stoptech BBK for racing usage on my Nissan 350Z
Both are 6 pot with 14" inch two piece rotors - awesome stopping power (with a nasty price tag)
Those hpa's look amazing! I was thinking of going seat Leon cupra r 310mm discs with the brembos, but there are none in aus so I'd have to get them shipped. Then whenever I need discs and pads if need to order online. I'm going to keep searching formums to find out if here are any other brakes other than 944 that are easy to bolt on.Originally posted by Martin View PostOk
[ATTACH=CONFIG]6991[/ATTACH]91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
Boxter rears might be a bit small.
You'll have to do the math and look at piston sizes.
It's possible that the MK2 stock pads have bigger cross sectional area and would apply more pressure.
Take a look on clubgti or ed38 for info on these sorts of conversions.
Remember though that brake conversions are based on what's readily available in your country.
Price and availability of second hand Porsche bits is much better in the UK/USA. Here you might be better of developing based on Subaru bits?79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
12 Amarok
The boxster rears are 4 pot, that's all I've looked up. That's the exact reason I started this thread, I was hoping mk2 or 3 people had done upgrades and new what was the best brakes to get in aus. I'll keep doing my research and hopefully find a good brake that's easy to get here.Originally posted by Peter Jones View PostBoxter rears might be a bit small.
Price and availability of second hand Porsche bits is much better in the UK/USA. Here you might be better of developing based on Subaru bits?91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
Golf mk2 GTi 8v
HAHAHA
