Coolant temp sensor connector terminal
  • Coolant temp sensor connector terminal
    Hi all,
    My coolant temp sensor (blue) connector wires is breaking too close to the connector (can't splce, have to cut it off). i was wondering if this terminals i found on ebay are same as the ones in the connector?
    BOSCH INJECTOR PLUG TERMINAL X 8 - Suits EFI Plugs | eBay
    Got Turbo Inside
    your local VW dealer should have (in Stock, wiring repair, yellow cables) ready prepared pins with a piece of wire on it and also 2 conectors.
    those pins that you found are to big, if it are these in the pic. the discription says for injectors, they will fit.
    you can use also the pins from the DIN Radio plug, they ar the same size.
      Thanks! I will give some of them a ring.
      Got Turbo Inside
        here is the part no. 000 979 133A
        these are with the gold contacts.
        dont no the no. from the normal ones
