G-8VXWWTRHPN air fuel ratio gauge installation? - VWWatercooled Australia
  • air fuel ratio gauge installation?
    hey guys iv been searching the net for nearly an hour to no avail, where will i find the signal wire i need to hook up my air fuel ratio gauge? i have a 1.8 8v digifant
    thx in advance!
    tom
    Probably the white wire off the lambda probe. What's the gauge wiring like? Do you have a 4 wire probe on there? I can't remember?
      Gav, I beleive Digi 2's run with 3 wire sensors.
      Assuming your O2 sensor is in decent condition, you'd simply splice in a signal wire from the gauge to the O2 sensor signal wire.
      Have a look at this
      Installation Air/Fuel Ratio Gauge by Duostyling VW gauge - My Volkswagen Mk2 Golf -
      HAHAHA
        im not sure where i should be actually looking in the engine bay in the first place :/ iv done a/f gauges a few times before but on newer cars where iv tapped off the ecu main plug, im still a bit new to vdubs and older cars in general, a pic or accurate description of where i should be looking would be a great help! cheers,
        tom
          Look down the back of the motor on the drivers side. The connector should be sat there on the engine mount.
          EDIT
          Use the information in the link, looks to be right to me.
            Hey mate,
            I installed a wideband ratio gauge in mine not too long ago however I had an additional sensor welded into the exhaust. I will put up some pics once I get a chance.
            Did the gauge not come with a sensor?
              nah mate, its an outo meter sport comp, i think its made with newer cars in mind so its just got +, - and signal wires
