Gearbox code
  • Gearbox code
    Where do I find the gearbox code? I'm trying to work out what gearbox I have.
    I've looked at the underside and the last 3 digits are 054. (I think)
    It's a 1984 8v GTI.
    Nobody??????
      hey i did a search and found this old thread. might be useful.
      Without Your Seatbelt, You Know Your Gonna' Die!
      Project: mk1 cabriolet 20vt
        Underneath the box at the bottom of the bellhousing is a flat plate. What are the first 3 digits??
        Or the complete number.
          9AO or 9OA**045 from memory. It's too low to see!
            9A is close ratio with tall final drive & 100mm CVs. Small input shaft (22mm) and should use the red speedo gear on the cable.
            Ratios are
            3.46 / 2.12 / 1.44 / 1.13 / 0.89 with a FDR of 3.67
            Pete
            7? MK1 Caddy
            79 B1 Passat Dasher Project
            12 Amarok
              So It's a good box or should I swap it out?
                Depends on how you want to drive the car.
                For track use you'd want a lower diff ratio, for highway use that's a great box.
                7? MK1 Caddy
                12 Amarok
