G-8VXWWTRHPN Rocker Cover Gasket Replacement - VWWatercooled Australia
  • Rocker Cover Gasket Replacement
    I'm replacing my Rocker Cover Gasket (Courtesy of Mrs Loon ) this weekend.
    The Haynes manual says the torque settings for the nuts is 10Nm although ive read that other people do it tighter, any thoughts?
    Ive done a couple of these before but not on the Mk2, anything else I should look out for, or is it a simple experience?
    Simon
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Sorry I missed you on the weekend mate.
    I just nip em up, dont do em too tight and snap em, just enough so they are tight and dont leak.
      No problems...ive got no doubt I will be harrasing you at some point soon
      yeah I cant see the benefit of doing them too tight as there isnt too much force at work on any of those points, just read in a couple of spots about people taking it past the 10Nm to "make sure" there are no leaks.
      I suppose, do them tight, if theres a leak at one point, tighten more. Makes sense.
        What sort of gasket are you using?
        The Bentley says 10nm and thats what I did mine with a good quality torque wrench and it does not leak at all. My rocker cover uses a rubber gasket which are better and can be reused, also the sump gasket is of a rubber material, no leaks.
        sigpic MK2 GTI G60
          Yep rubber gasket it is....hopefully should fix the leaks...
            I replaced mine with a g60 rubber gasket years ago and havnt had a problem since. Just be careful that the metal studs/sleeves whatever you call them arent too thick and prevent the gasket from sealing. If they are you can easily remove them. Goodluck
              Got a slight leak still even though its nice and tight, might be those sleeves in the rubber gasket? Not sure....reckon I should try taking them out?
                yep, pop em straight out. Just be careful you dont tear the rubber of the gasket.
                  Time to resurrect a long dead thread....
                  I replaced my rocker cover gasket about a month ago with an upgraded MK3 rubber gasket. It came with new shoulder bolts, which is used as a replacement for the old ones.
                  The start of this week i noticed a funny noise coming from the engine which turned out to be cam belt cog needed a bit of oil so i wipped off the cover and oiled it. Noise disappeared, but the damn gasket started leaking again.
                  All the bolts are nice & tight but have i disturbed something by doing this?
                  I am going to take off the rocker cover and re-seal it this weekend and i was wondering if it would be a good idea to use a gasket sealer of some kind.
                  Also i don't have a torque wrench but last time i just hand tightened the bolts last time. How can i tell if they are over tightened or not?
                    Hey Mate,
                    how did you end up going with this?
                    VW MK2 Golf GTI 8V 1991
                    VW MK3 Vento 1995 Daily Driver
