GTI master brake cylinder replacement.
  • GTI master brake cylinder replacement.
    Damn roadworthy,
    (Golf Mk2 GTI 8v 1990)
    The master brake cylinder needs to be replaced, cant i be replaced with a SEAT cordoba one?
    There will probably be more things I will be asking. Damn roadworthy to hell!
    *More*
    I need the drive shafts to (if thats what there called on a FWD). Both sides, can they also be taken of a SEAT Cordoba?
    Does anyone know where i can also get a windscreen for the mk2?
    Thanks guys.
    MK1 GLS 3door
    A4 B7 2.0T
    What year Mk2? Is it an Aussie one?
    Drive shafts from a Cordoba are the same.
    Master cylinder from Cordy will work, but may not have the same number of outlets. It does have T piece brake line splitters so you could use the whole line with them attached.
    Brake Booster from Cordy wont work, the inner end is different.
    I have a Mk2 booster here if you get stuck.
      Thanks mate, ill let you know.
      The GTI is a 1990 german one.
      MK1 GLS 3door
      A4 B7 2.0T
        Member "qsz" is wrecking Mk2, not sure if windscreen is available still but might be worth giving him a PM to check, is in Melb by the way.
        1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
