Ok am trying to get this golf engine to kick over. Has good spark. Has petrol. Spins but wont start, then gets slower and slower. Battery I thought, put it on recharge.
12 hours later, starter barely spins the engine and it stinks of petrol. But there is no petrol in the filter, says my brother in law. Thanks Pete.
Put some petty in and look in the carby, it is full to the brim. So presumeably are the cylinders. A check on the oil reveals that it reeks of petrol. Glad it didn`t spark now!
OK, so I rebuilt the carby and freed up the petrol inlet cutoff. I should explain that this is a strange carby from South Africa and that the car has electric fuel pump and fuel pressure regulator. Petrol seems to be stopping at the cuttoff, but there still seems to be a constant trickle into the other chamber of the carb when the fuel pump is on. Is this the idle jet, Or do I need to take the carby apart again?
Drained the oil, which stank bad and had gained a litre or two! and took the plugs out (they were wet and petrolly). Feeling a bit lightheaded, i came in for the night.
Hopefully the morn will see it working, but if anyone has any helpful hints, let me know.
