import yes, do it
aussie delievered, don't bother. Too much mucking around with emissions etc (blue slip every year no?)
the poms love thier bike carbs, if you're handy with a welder and some pipe, go nuts. A set of bike carbs can be had a bucket load cheaper than a set of twin 40's. you can even buy manifolds (allbeit from OS) for them, to suit bike carbs. hpoe this add some fuel to the fire!
Pete Jones runs a 8v on carbs (his track car), i know of a few back in the uk that ran welll and of course you have the best sound track in the world!!!
bike carbs is abit more tricky as you need to make a manifold up.
but i think head work and cam would be the first thing to do, also you will never get massive power, just a nice torquey engine
I've heard that bike carbs are a nightmare to get right, don't really give that big a power increase and cause your fuel consumption to plummet. On the other hand the look monumentally cool, sound awesome and would be very unique.
As mentioned above head work, a twin weber/dellorto or simple engine conversion would be a better bet. Whack a VR6 in it!
I don't like GTI's on carbs and for the amount of work and money involved to get it right the power isn't really worth it imo. You can still get 150hp out of a digi 8v with not a lot of work.
If you can find a vr6 donor it wouldn't be to hard to do the conversion, there are plenty of 'how to's' on the net and if you are handy with a spanner you should be oright. As far as i know the wiring is prity much plug and play.
Sorry for hijacking but HOW!!!!
I'm guessing , porting/polishing, bigger valves, cam and exhaust?
Details are up on ClubGTI. They have a whole thread dedicated to mk2 2L 8v power figure and times. It takes the usal 2L bottom end, cam, full exhaust and chip but to really make it pop it needs to be ported out 38/40 valve size or even bigger to break the 150hp mark. Thats the key really. At about 145hp you need to upgrade the clutch though.
Having been through all this in 96', I can say that a well fettled 1800 or 1900 8V is the best solution.
I had a MK1 GTI with an 1800 bottom end, TSR Pack C head, TSR 103 Cam, vernier pulley, exhaust manifold and an system. Dyno'd well over 160 at the crank.
It went like a train.
When the bottom end wore out I fitted a 2E bottom end under it which ruined the feel entirely. It was torquey but massively thirsty. To get adequate fuelling at the top end it ran rich everywhere else. The 1800 would rev like a 16V but the 2 litre was all in by 6k.
As an 1800 it would do 40 MPG at 70 on the motorway, 400miles on a tank was easy, as a 2 litre it wouldn't see 300 most of the time.
So the up shot is to modify the 1800 will cost you. The head, cam and vernier in 96 were over 1000 quid. Then there's the manifold and system. You need someone with Kjet knowledge to set it up. I can advise on that to a degree having taught myself about it.
My advice for an instant 30hp is to fit a 16V like I did in evorobin's digfant GTI. An ABF conversion would be the best bet. Having had just about every 4 pot made by VW since my first MK1 in 92, the ABF has always impressed me. The power delivery and throttle response and nearly K-jet like compared to the laggy nature of the mk2 digfiants.
I know we are in Australia but they are available.
A 16V KR cover with a plate to match the gearbox is the way to go for a clutch.
Brakes would be a sensible thing to upgrade too. 256mm would be a starting point.
You should probably rego it first mate.
It also seems a shame to mess with one of the first GTI Mk2s built and one of the few 2 doors out here.
19-20/6 Badgally Road, Campbelltown, 2560 02 4627 3072 or 0423 051737www.camdengti.com
