Originally posted by 8v ggggti
View Post
On low volumes where the high current is only drawn ocasionaly they work because once the peak is gone, the cap can charge back up with the left over current.
On high volume where high current draw is constant the caps only add to the load. If your constantly drawing high current the cap is going to discharge and is going to be trying to charge back up.
There like inefficient batteries and usaly used as cheap short cuts.
For example if your car has 70amps to give and on low volume your amplifiers will draw 40amps than the cap can draw 30amps to recharge itself without taking any away from the amplifiers. If you turn the volume up and the amplifiers now draw 70amps (with peaks above 70amps that discharge the cap) the cap now has nothing to charge from without drawing current away from the amps or just being a expensive paperwieght.
The reason peoples lights dim is because the voltage drops as the current increases. As i said before 70 x 14.4 = 1008, if you increase the current draw the voltage has to drop for the total power to equal 1008.
Im running a total of about 1500watts RMS (so a bit shy of 3000peak) in the mk1, i dont have a cap or a 70amp alt but my lights dont dim.
