I have been driving and doing up my 8v GTI 1990 RV code engine Golf for the last year or so. In that time i have had the head completely reconditioned and a high lift cam put in. 4 into 1 Tubular exhaust manifold (extractors for you aussies).
I have tested the Idle Stabilisation valve to check it's functioning properly according to the Haynes manual and it is. Also checked the infamous blue ECU water temp sender by unplugging it whilst the engine is running and it certainly makes the engine struggle until it gets plugged back in, so i guess it must be working. I have tried to make it idle around 850RPM by adjusting the allen screw in the Air flow meter but nothing happens from fully in to full out yet it runs and idles around 1000RPM.
I have also played with the fuel/air mixture screw but i can't seem to get the exhaust to chuff out anything but that sweet smell of overfuelling. The only thing left i can think of is the Lambda Probe is faulty.... Any other Suggestions???
Also when the aircon compressor is switched on and i blip the throttle the engine cuts out from being overloaded.
