Fuel Pump pressure question
  • Fuel Pump pressure question
    Gidday.
    Can anyone tell me if the mk2 GTI fuel pump for the RV engine (digifant II) is 3 bar or 4 bar??
    The number of the pump is 191 906 090.
    Cheers,
    Wade
    i think its 4 bar but the fuel regulater will drop it down...i know the perfance high pressure regs are 3.5 bar! (so i would guess the the fuel pump would pump harder and the regulater will drop it down)
    Velly
    '91 2.0 8v GTI
    Originally posted by DubSteve
      You need to consider flow, as much as pressure Wade. 4BAR to supply a 100hp motor, is a fair bit less fuel than 4BAR to run a 300hp motor.
        Gavin,
        Got myself an adjutable regulator, and looking at taking it from the stock 3bar to 3.5 possibly more once I add the 735i AMM. A 4 bar fuel pump is good to _____ hp?
        Cheers,
        James
          Ok thanks.
          I'm a bit unsure what to do. Do i leave the old mk2 pump setup there and feed the AMK with that? Or is it too weak and should i get the VR6 setup?
          I still have the old S3 pump, and was hoping maybe i could put the actual S3 pump in the mk2 housing??? I'm really stuck???!!!
            i'm running with a vr6 tank and in-tank pump at the moment. i wouldn't worry so much about a vr6 pump under-fueling, but perhaps the original digi pump might struggle a bit.
            considering the injectors for the stock 8v are less than 200cc, and the tt 225 injectors ( same as AMK?) are something like 315cc, flow rate might be an issue with the stock pump.
            i'd fit the vr6 pump just to be sure.
            edit: dont think the s3 pump will fit in housing, never tried, who knows?
            87' MK2 GTI
            13' MK7 TDI
              Wade, go through ETKA. See what tank is in the G60 Golf GTI PG engine code, if that has the same part number as one for a digifant Golf PB engine code. You will be game on with the VR6 pump. I broke the pump in my G60 and used a VR6 one as a replacement.
                just get it running with what you have Wade, then mess about with the pump if it isnt up to scratch.. the Std K jet will flow enough to get it idling at a bare minimum.
                Lots of MK 1 Scirocco's...
                Cheers,
                Grant...
                  I forgot it was Kjet, easy to get a Bosch 044 I think it is and bolt in in the same place as the original. You need that wideband so you know it hasn't gone lean. Be a shame to wreck the motor over a fuel pump.
                    No my car is a 1990 GTI with digi II, NOT kjet.
                    I'll leave it as is and see if its leaning out.
                    cheers for the advice guys
                      You can probably go with a VR6 pump if you need it. Please be vigilant when you first drive it!
                        mhmm.. if possisble, do an simple test how long it takes to fill a litre or something to get a gauge of how much it flows. alternatively, just etka the mf.
                        get a wideband on that asap too. getting the correct tune is geniuniely impossible without
                        87' MK2 GTI
                        13' MK7 TDI
