mk3 aircon into a mk2
  • mk3 aircon into a mk2
    has anyone done it?
    if so what is needed...i need to fix the air in the gti lol
    Velly
    '91 2.0 8v GTI
    Originally posted by DubSteve
    If you can figure out how to make it fit I've got a full set of MK3 a/c kit that needs a new home.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      we will talk on sunday fella
      i will do some more digging into it tonight online
      Velly
      '91 2.0 8v GTI
        I have done it.
        Use the Mk2 AC Box that is inside the car, assuming you have an Aussie delivered GTI.
        Use the Mk3 belt setup, bracketry and compressor.
        You need to get the Mk2 and Mr3 hose joined together as the fittings on the end are different.
        I also had to move the radiator 10mm forward to clear the compressor on that side.
        Thats it, have fun.
          cheers matt, i am missing a hose for the mk2 set up and the condenser has a fitting broken off.
          VW wanted 500 bucks for the hose alone!!!!! (its the one with the low preesure cut off switch)
          I am going to try a local aircon fitters to see if they can help too.
          Velly
          '91 2.0 8v GTI
            ok, i will take the mk3 stuff off your hands...you have mail
            Velly
            '91 2.0 8v GTI
              You need the Mk2 condensor, but could probably use a Mk3 or SEAT one.
              Toledo is definately the same.
              If you have the ends of the hoses, all is possible.
              Or just man up and wind down the windows
                lol...i have the condensor but one of the fittings is broken but i guy at the aircon place said he can get the fixed, failing that i will order one from the us of a
                Velly
                '91 2.0 8v GTI
                  on CGTI they are telling me i need to change alternter / PAS pump and water pump!!! all to mk3
                  I am getting the set up off pete, it is complete
                  Velly
                  '91 2.0 8v GTI
