whinning noise from engine bay
  • whinning noise from engine bay
    hey guys im gettin a whinning noise coming from the egine bay when going 100km/h onwards
    any ideas what this could be? noisey belt???
    85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold )
    91' MkII GTI sold!
    Spray a bit of WD40 on the belts and see if to goes away. Dont spray to much because it might cause the belts to slip. I usaly spray it on while the engine is running and stop spraying when the noise goes away. There is also a lub stick you can buy for belts, its like $2 from an auto store.
    Although, i dont think that its your belts making the sound, as you say its only happening over 100km/h. Taking a guess it could be your gear box or something that is just making the noise because of the air rushing through.
    MK1 GLS 3door
    A4 B7 2.0T
      I used to get a whining noise coming from the passenger seat,
      divorce fixed it,
      Good luck finding your noise.
      "That's what she said"
        divorce fixed it,
        LOL!!!
        MK1 GLS 3door
        A4 B7 2.0T
          yeah i think it is air rushing through the gear box,
          and LOL!
          also noise usually happens at night when really cold and driving, not on idle, rev it out a bit and the noise disappears
          91' MkII GTI sold!
            and LOL!
            I didnt mean air rushing through the box, i ment air rushing through anything an creating a sound. Could be a bit of plastic or something.
            Is the sound in every gear and would you be able to describe the sound. Does it get louder or faster as you rev?
            MK1 GLS 3door
            A4 B7 2.0T
              Haha Kosta? Didnt realise it was you. Tellin you shiz you already know.
              MK1 GLS 3door
              A4 B7 2.0T
                not the supercharger is it??
                I would suspect noisy timing belt (ie done up too tight) but that you notice all the time, in every gear, and (obviously) it's related to engine speed.
                try and figure out if the noise gets louder as you go faster (speed) or as the engine speed increases (rpm)
                  mate its the belts just lube them up a little
                  sigpicThe Mk2 GTI Baby
                    if your belt set up is original, it should be running v-belts yes?
                    there's a tensioner bracket on the alternator, which requires a 13mm spanner and a big! (26mm ?) to tighten. it sounds like your belts are slipping. if you nip them up it might do the trick.
                    does it do this when it's really rainy as well? if yes, then the belt is slipping on the alternator pulley wheel.
                    87' MK2 GTI
                    13' MK7 TDI
                      thanks, guys, havent had a chance to check it all out yet, but i shall check this weekend, and lol dado as if u didnt look at the username haahaa
                      91' MkII GTI sold!
                        actually, i started the car up today for the first time in a few days, the ar was freezing, i have a feeling it might be from the actual fuel lines, its a 1.8 L kjet, so im not sure if anyone else has experienced this before? could fuel line make noises when there really cold????
                        91' MkII GTI sold!
