Purchased a pod filter from autobarn for my mk2, i need some installation advice....
mk2 pod filter install
Whats the diameter of the pod filter for starters?80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Originally posted by salem1 View PostPurchased a pod filter from autobarn for my mk2, i need some installation advice....
Anyway..like Mr Houso said...a little more info would be good. diameter? what did you get in the kit as far as brackets etc?1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
If it is a digifant car you will need an adaptor plate as the air flow meter is square and the pod will be round. You will also need a bracket the hold the air flow meter. I have some pics of the kits I have, I don't have it on the car anymore so may sell it if you need it.
cheers,76 MkI 3 door - daily drive/project - 1.8 5speed
Originally posted by salem1 View PostHere Is The Info:
I Bought The Adaptor Plate, Bracket And The Air Flow Meter, Should I Watch Out For Anything, I Am Worried Is It Really Going To Decrease Power ...80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
bit late but everything u need is at autobarn and i dont recommend a poddy anyway. You can make a heat shield urself. Use cardboard for making the template and then cut it from sheet metal.
Ive got a used K&N panel filter, it neads a clean and re-oil but a drilled box with a K&N is better than a poddy.MK1 GLS 3door
A4 B7 2.0T
