G-8VXWWTRHPN $4k to upgrade a gti - VWWatercooled Australia
  • #16
    that's pretty average imo.
    Haha.. that was the best sounding one I found in 5 mins on youtube.. And I'm sure OP can get something that looks a little nicer than that fart can
    • #17
      if you choose to go with 1 pipe all way through, make sure you:
      1. dont forget to add the Cat
      2. dont let the highway patrol catch you and use that stupid DbA meter
      (got done be4)
      3. wont have much use since the AU mk2 gti extractors are the same as RP engine which is the german 90hp mk2.
      get full extractors with high flow cat all way through with 76mm for about 1500 if its custom built or around 1000 inc the extracotr if you find one on ebay.
      my exhaust man did full piping exept the extractors, but incl the hiflow cat 76mm through with twin dtm enpipe for $500 and he wanted 500 for custom extractors.
      And if anything install coilovers yourself.
      Takes about 20-30mins. saves you alot of cash
      Golf MK2 Project
      Daily car: Audi 90 2.3L 5cyl manual
      "I run everything under pressure, from my supercharger to my blood"
      • #18
        I'll leave exhaust for now I think, power should be fine for now and the money might be better put elsewhere.
        I'll try the coilover install with a few friends first, but if we get stuck, jmac should give a good deal on install to vww members.
        • #19
          nah man, you wont get stuck with them.
          front ones have 3 bolts and rear have 2 or do both have 2??????
          been working on skyline lately.
          think its 2 bolts on top under bonnet and 2 on the back of the brakes.
          the ones on the back of the brakes are a pain in the ass to undo cause they tighten over time.
          good to have a really strong wrench.
          think top was 14mm and bottom was 17mm.
          but yeah. MK2's are basic cars and so easy to take apart. just make sure you have level ground and set up your coilovers to the right height.
          the skyline got modified and got stuck on the jack. was 20mm of the ground.
          also remember that suspension settles in once you drive it. after about 20km they settle in and fully lower themselves.
          mine set about another 10mm when i started driving.
          Golf MK2 Project
          • #20
            mk2 brake upgrates
            i have two sets of mk3 Vr6 brakes provided you buy a set of Seat cupra discs, vr6 brakes will bolt to your hubs and are 280mm which is more than adiqute for a mk2
            • #21
              if you are going to any part of the exhaust fixed.. please please please upgrade the exhaust manifold! PM loon and see if he can post you a later 8v exhaust manifold.
              mk2's handle really nicely with some lower springs and good shocks, along with some decent rubber. you can pay extra for coilovers, but the cost/improvement isnt worth it in my opinion.
              You can make 4k go a long way, or blow it quickly and have a slower car.
              good luck and have fun!
              TDI mk1 on the road!!
              • #22
                I don't know why they are telling you to get bigger brakes, all you will have then is a slow car with big brakes. Waist of money.
                If you are going to upgrade handling before performance then you will sooner be busted for using the handling mods than any performance mods.
                The stock brakes will do fine until you get more power then a UK spec 8v.
                Get the coiloveries and install them yourself, that will save you a bunch of money, hottuning will save you even more money and are a decent coilover, the car will sit low and will handle well with hottuning. Its up to you if you want to spend more on something better. I still wouldn't fork out more for a fancy set when my car is slow.
                You have to remember that the car handles great in standard form but the engine doesn't perform well. I've got a set of hottuning and a good set of tyres and i can point the car in any direction at just about any speed and it will go there, it usaly just depends on how fast you can turn the wheel more than what mk2 can handle.
                You should at least look at getting up to UK GTI spec.
                Get an exhaust, cam, 2L bottom end and coiloveries. You should have ~90kw at the motor then worry about brakes and sway bars. If you are going to drive it hard as a daily then get some better pads and GOOD tyres. Your cars handling is nothing without GOOD tyres.
                MK1 GLS 3door
                A4 B7 2.0T
                • #23
                  What do you mean by slow? What is its 0-100 time with the extractors and de-cat? (or even stock 0-100?) The owner thinks it has about 85kw at the engine (77 stock).
                  Ok, so after coilovers and audio I'll look into exhaust. Cam and 2L bottom end you mention, I'll have to read up on that, haven't heard about it before.
                  edit: A quick google says the 8v should do 0-100 in 9s, and the 112hp (83kw) version should do 8.3s. So I'm guessing this one is around 8.5-9s, slow I guess, so I'll compile a list of engine mods to do in the OP.
                  • #24
                    If the motor hasn't been changed then its an RV which comes standard with 77kw. If you have a full exhaust then you are looking at maybe 85kw since the most restrictive part of an RV engine is the exhaust. Stock RV 0-100 is about 13sec according to when i hit the gas and counted in my head lol. With exhaust and de-cat i cant say, maybe somewhere between 10sec and 13sec.
                    With a cam you will gain a few more kill wasps and with a 2L bottom end you will have a lot more torques. The cam is prity straight forward and you can find a lot of info on the net, there is also a DIY guide on ClubGTI if needed. Most popular is a 270 or 276 degree cam. I just bought one yesterday.
                    The 2L bottom end conversion is also very popular and cheap if you do it yourself. There are a few bottom ends you can use but the easiest to find is a 2E tall block. For this conversion you will need a 2E dizzy, 2E head gaskets and head bolts. You bolt it on and plug the mk3 oil breather hole. I think that's it as far as i can remember. I was planning on doing it myself so i did a lot of reading on it but recently bought a mk2 with a 2E bottom end already fitted.
                    My first mk2 which i smashed had a stock RV motor, stock exhaust (minus one muffler, sounds mad), hottuning coilovers, ebay chip and K&N panel filter. Slow, so very slow but sounded fast lol and handled great. I couldn't out run a corolla.
                    The mk2 I have now has a mk3 duel down pipe and manifold, mk3 cat and a 2L bottom end. I kept up with my mates 5.7L VT in first and half way through second and a VZ SV6 Ute had trouble keeping up with me. The car is out of tune, timing is off and its not road worthy.
                    I have a full stainless steel exhaust (no-cat) from the manifold back, 276 TT cam and the ebay chip lined up. When its all in and running well I will run it on a dyno and see what comes up, im very curious to see what the difference is.
                    MK1 GLS 3door
                    A4 B7 2.0T
                    • #25
                      my stock rv did 0-100 in 9.8secs. the 16v did 8.3.
                      as said, the exhaust is main thing you do need. dont de-cat it. for one its illegal and also i think the AU MK2 have a G-kat with is a regulated cat which means your engine adjusts to to how much petrol it puts in. if no cat then all of a sudden your engine cuts down fuel and you wont run properly.
                      Golf MK2 Project
                      • #26
                        Spend like $1200 on some Weitec coilovers and get some phat 15's or 16's. Get a nice 2.25 stainless mandle bent exhuast and upgrade the brakes with some good pads and rotors. Also go through the whole car and replace worn and old parts.
                        Id also get a single head light grille.
                        • #27
                          If I was you, I would drive the car for six months get used to it and than decide.
                          Audi B4 80 Q V6'94 Race Car !! KEGGED
                          Audi B4 80 V6 Avant'94 Only one in the country that I know of !!! KEGGED
                          Subaru Forester XT'06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
                          --VW Bora V6 4mo'01 Gone
                          • #28
                            i wouldnt bother with any brake upgrades , if you dont have increased power the car will be slower , due to the increased rotational mass. i would change the wheels for some 16" bbs and get some good tyres , check all rotors and brakes pads to make sure they are in good shape. and keep the money for when something brakes and rego/ insurance . drive the car around for a month to see where you would like to spend the money.
                            cheers brenton
                            MK1 4door
                            MK2VR6
                            MK3VR6
                            Transporter
                            1st place, stock MK3VR6. Vw nationals 07
                            2nd place, mod MK2VR6. Vw nationals 09
                            and untold wrecks
