RV head vs. PB head
  • RV head vs. PB head
    Are there any other differences other than the valve sizes? Does anyone know the intake and exhaust valve sizes on each head. I think the PB head is 40/33.
    The reason i ask is
    1: I've always wanted to know but could never find out.
    2: If the valve size is the only difference, would it be cheaper to port the RV head to 40/35 and reco it rather than do the same to a PB head.
    Also, can anyone give me a rough price on increasing the valve size from 33mm to 35mm and what else is involved.
    I'm keen on a 2l bottom end with a ported PB head, duel down pipe and cam running digifart.
    P.S. I know about 16v's and vr6's so no need to tell me again lol
    MK1 GLS 3door
    A4 B7 2.0T
    Anyone? Loon....Preeny?
    MK1 GLS 3door
    A4 B7 2.0T
      well if you can speak german u can go to www.motortalk.de
      and ill also post a thread on there.
      biggest well... motortalk in germany to do with all german cars.
      also doppel-wobber.de aswell tells u data of every engine by vw incl VIN decoding.
      but in german
      ill ask round
      Golf MK2 Project
      Daily car: Audi 90 2.3L 5cyl manual
      "I run everything under pressure, from my supercharger to my blood"
        Thanks mate.
        MK1 GLS 3door
        A4 B7 2.0T
          ok, so i asked the guys and they said its the exact same head no diff just that the PF is the original GTI engine, the PB is the the same head just no oxygen sensor and no G-Kat, the RV is still same head but incl is the Digifant chips arent the same (PF and PB more powerful) plus the exhaust manifold is that of the RP 90HP engine.
          anything else ask me and ill figure it out
          Golf MK2 Project
            I just want to clear it up.
            So the PB head and the RV head are the same BUT the PB engine has a different Digifant chip and a different exhaust maifold which makes it produce more power?
            Is the correct?
            Thanks alot mate, im glad someone could help.
            Anymore info from anyone would be great too.
            MK1 GLS 3door
            A4 B7 2.0T
              yes, thats correct.
              this is a website, in german but you might be able to pick out a couple of words in it but its german and has all car engine info:
              like i said any questions you need answered i know a few vw mechanics and alot of vw enthuthiasts
              Golf MK2 Project
                Thanks mate,
                the link is great, ill try use and online translator and see how i go.
                MK1 GLS 3door
                A4 B7 2.0T
                  anyone know how much more power we are talking?
                    just go to the website I posted the link to and it has all engine details of all golf mk2 models on it, like a mini datasheet.
                    doppel wobber link
                    tells you power diff there.
                    its about 5-6hp worth
                    Golf MK2 Project
                      That was a great link. very much worth the click!
                        thought it could help a couple of people. i can get the PF or PB digifant chips or full ECU if anyone is interested.
                        shouldnt be more than 60 bucks i think but not sure
                        if i could find my tuning chip i could sell that.
                        boasts to about 123hp
                        would sell it for 50 bucks
                        Golf MK2 Project
                          RV engine makes 100hp or 77kw
                          PB engine make 112hp or 83kw
                          Doesn't sound like a lot but from what i have read the PB engine performs a lot better.
                          To turn a RV in to a PB (going by what i have read above) it will take about $200.
                          If you can get the PB ECU for 60$ ill take one please.
                          MK1 GLS 3door
                          A4 B7 2.0T
                            ok, ill check what i can do, well pb and pf is the exact same ecu really onme was just for german market and the other for the uk market.
                            so if people needed parts etc they knew uk or germany. ill check it out and pm u when i get any news.
                            if im lucky i might be able to get upgraded ECU from PF with the chiptuning in it to make it the 123hp straight out of the box.
                            But you need to change your cams VorOT to 12 degrees instead of 3 degrees.
                            not that hard really just timing gun and your right.
                            if you dont want the chip in it let me know ill search for plain one.
                            cheers
                            Golf MK2 Project
                              cheers
                              Ill take the chip in it aswell.
                              PM Sent mate.
                              MK1 GLS 3door
                              A4 B7 2.0T
