G-8VXWWTRHPN Door Trim Removal - VWWatercooled Australia
Door Trim Removal
  • Door Trim Removal
    Hey ppl im afraid im being a bit lazy here but can anyone please tell me how to remove the door trims. I think i just have the window winder left to get off but it seems a little tight to have a clip on.
    Thanks heaps!
    There are 2 screws on each side(2 near hinge end...2 near lock end), the two screws that hold the handle in and then the window winder which you just need to flick the cap off with a flat head to get access to the screw itself.
    Then there should just be the clips at the top/bottom which you should be able to just pull the door card out carefully without damaging it.
    I think thats it...
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
      the window winder is screwed on. the little cover clips off, you'll see the screw underneath.
      so much easier than those stupid clips.
        don't forget the door handle surround which slides forward then off! Try not to break the tabs off.
        mk2 GTi 16v
        Corrado G60
          a screw in the middle of the winder huh? who would have guessed. Please ignore my obvious stupidity im new to this golf caper. Thanks heaps for the help ppl!
            Nothing stupid about that.....what would have been stupid is to not ask the question then use a crow bar to rip the door card off
