Golf 2 Shipments to Australia
  • #91
    Originally posted by moto View Post
    I just checked for this but Bentley gives no listing for a PB engine or for any 112hp engine.
    The Bentley reference table I'm looking at is on Pg6 of the Engine section.
    The only 112 hp engines I know of were in Mk1s. The last of them (the 1800) was a DX engine. The very early Mk2s produced in 1985 did come with mechanical valve gear like the Mk1. Is it possible PB engines were a small batch of surplus Mk1 engines supplied to a specific market just to clear them? Its strange Bentley doesn't list it.
    The 112hp engines were K-Jet not Digifant and ran throughout most years.
    • #92
      According to ETKA
      PB 82KW Digifant
      PF 79KW Digifant
      RV 77KW Digifant
      I will see if I can do a dump of all the engine prefixes and ratings possibly with VIN
      sigpic MK2 GTI G60
      • #93
        PB is the engine that the UK got in it's GTIs. From about 86 through til the end. 112BHP same as the mk1 DX and the MK2 kjet EV.
        • #94
          Syncro when people (poms) that have owned this engine post about it you're going out on a limb to disagree mate.
          • #95
            I thought that the EV engine was used up until 1987
            my old EV engine was made in 1987 (it was a cracker) & came from a car that was wrecked in Germany
            So did they have more than one prefix code going at once eg differnt countries= different prefix
            • #96
              So did EV/PB use hydraulic valve gear or were they a direct carry over from the mark 1 (ie manual adjustment)?
              • #97
                Digi injection started in 88
                • #98
                  How many poms have had a Digifant GTI?
                  Sounds like some of the poms are a bit like the seppos. If it didn't happen in the UK, it didn't happen!
                  • #99
                    Millions
                    • Originally posted by Golf Loon View Post
                      Millions
                      So they had slugs too?
                      Most of the ones that I've seen were K-Jets.
                      • Originally posted by moto View Post
                        I did a trawl and found out from a Corrado club in Canadahttp://www.corrado-club.ca/tech/vwecucodes.htm
                        The PB was a
                        Golf GTi 1.8 litre 8 Valve
                        engine
                        Years- 88-89
                        Notes- KEN Digifant II
                        Golf GTi 1.8 litre 8 Valve (PB)
                        88-90
                        KEN Digifant II
                        88-90
                        KEN Digifant II
                        88-90
                        KEN Digifant II
                        89-90
                        Siemens Digifant II
                        88-90
                        KEN Digifant II
                        88-90
                        KEN Digifant II
                        90 on
                        Bosch Digifant II
                        90 on
                        Bosch Digifant II
                        sigpic07 GTI
                        APR stage II
                        • Originally posted by syncro View Post
                          Well if you moved from the UK at the start of 1988 that would explain it...
                          • I've got an EV under the bench and it has hyd lifters and went like mad and was k-jet originaly, now ....... it's in bits..
                            i'm running the pl 16v in the golf now and i believe it also was orig k-jet, and it flies, just lacks a little hp up high.
                            detuned kr i hear with the only diff being the inlet cam.
                            Dave
                            ______________
                            MK1 GOLF 16v
                            • Dumped from ETKA, maybe too much clutter in this post ?
                              Year 85 Engine Codes
                              Trans Codes 85
                              VIN 85
                              sigpic MK2 GTI G60
                              • Engine Codes 86
                                Trans Codes 86
                                VIN 86
                                sigpic MK2 GTI G60
