Golf 2 Shipments to Australia
  • #31
    Originally posted by rowan_bris
    My Silver one is 8/90 and complianced 1/92. I have a white one arriving on Thursday and will add that then
    Sounds like one that was sitting around waiting to be sold.
    What was the compression of the cabrios then Golfwise?
    • #32
      GTI=10.0:1
      Cabrio=9.00:1
      • #33
        What engine code would those cabs be? surely an ideal motor to turbo?
        • #34
          I believe the biggest difference between the euro heads and Japanese/ Australian spec heads were the big valves, which were absent due to emissions... VW couldnt afford to pump money into the 16V or the euro 8V to produce a decent outcome with emissions being as they were only just re-entering the market. The Japanese motor was a quick cheap easy fix, and lets face it, in 1990 when the decision was made, the GTI didnt have too much competition locally....
          Euro look 2... Mk2 love!
          • #35
            Heads and valves were the same. There was probably some tweaking to the management system because the Au cars will run happily on 91 octane ULP - thats all we had in 1990-1.
            Has anyone else changed the exhaust manifold and system?
            • #36
              I have not changed the manifold but have got a Jetex cat back stainless exhaust. I have the ecu rechip in the RV motor and a K&N filter. Performance was better but not great more noticeable when weather is cool. Some occassion's it even spun the wheel when changing from 2nd to 3rd, but on a flat road.
              My MK2's build date is 08/90 first registered by me 05/92.
              VIN WVWzzz1GzLWxxxxxx
              Is it only power that makes a true GTI, not the chassis ?
              sigpic MK2 GTI G60
              • #37
                [QUOTE=moto]Heads and valves were the same. There was probably some tweaking to the management system because the Au cars will run happily on 91 octane ULP - thats all we had in 1990-1.[QUOTE]
                I reckon the euro cars had bigger valves than the aussie cars.
                • #38
                  Originally posted by aussieg60
                  Is it only power that makes a true GTI, not the chasis ?
                  Its the chassis number.
                  Purists will also argue that anything with 4 or 5 doors cant be a GTI.
                  • #39
                    As if VW didnt treat GTI's t o a bit of extra care when they were being built. Thats like saying R32's get built the same as a 1.6 pov pack MkV... Actually, I am only guessing. I wonder how much of this is true.
                    I still reckon the Aussie ones had smaller valves... the difference is pretty huge between the euro GTI's and the Australian ones.... The latter just wont breathe....
                    • #40
                      I think they were the same.
                      Could easily check if I had some engine numbers.
                      Remember it had a completely different injection system.
                      • #41
                        Isnt it Digifant? I thought it was digifant with a smaller valve head for emissions. The head would be the biggest difference with emissions, so it makes sense...
                        • #42
                          Yes digifant.
                          As far as I know there is only one size of valves for GTIs.
                          I need the engine numbers for a K-Jet and an Aussie Digifant to check.
                          • #43
                            Around 86-87, the Euro GTI's went to Digifant....
                            • #44
                              They came off the same line, built by the same people
                              • #45
                                I havent got a digi head off the car, so cant take pics of both.
                                The kjet uk spec cars had 38mm inlet valves. This is the same as 2L audi and Mk3s.
                                I reckon the digifant valves were smaller. If you put a kjet head onto a digifant motor, you get more power.
