Gday Mk1 people!
I have been lurking around here for months now so it's time to throw some grand ideas of mine around for discussion.
I've done some reading here in the forums but may still repeat some things you guys have already covered - if so just tell me.
Have been given a '79 GLD that is running and very capable of being registered again. Has had new rings put in by my mechanic friend who gave it to me. I wouldn't let him repair my cars, he's a butcher in my eyes (I am the complete opposite, but anyway).
Motor has some oil leaks. Has around 200,000 kms on it. Hopefully just sump leaks rather than main seal.
The body has some rust I was not happy about (lots) so I found a good friend of mine interstate with an '80 with a cracked head, always garaged, essentially rust free. The engine bay is immaculate - like new.
Was going to transplant the running diesel motor from mine into it but then again it may be better to just transplant the head. Any thoughts?
Also, after I have the new car on the road the plan was to fit a small turbo (low boost) to it. I haven't read much positive talk about it here yet. Heat seems to be the main issue?
Was planning on fabricating a new inlet and exhaust manifold for the turbo and running a large enough intercooler to keep the charge temperatures down. I may even run oil/lubrication injection to the valves if required.
I was planning some serious oil cooling and increasing capacity to keep operating oil temps down. The increased temperature (too be seen) may require a larger radiator. If a reduction in compression is required I would increase the head gasket thickness most likely. Is the increase in torque worth the hassle?
Sorry about the long post. 6 posts in 1.
