as the picture shows, the carby sits 180deg. to all the webers iv'e seen on golfs. are there any pro's or con's the way it is?
weber carby position?
Carburetors can be side draft or down draft - the float chamber is different between these configurations
Side draft is probably better as it has a direct airflow into the head - but needs a lot more space
Down draft will put the air flow through an elbow, this configuration uses less space but is taller
Both work really well for street cars
In Motorsport there would be a preference for side draft
But it's mostly fuel injection and ECU these days which is far superior to carburators2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
sorry, I was meaning on this car the fuel bowl is on the right and throttle linkage are on the left, while all the other down draught weber setups, show it the other way round.Originally posted by Martin View PostCarburetors can be side draft or down draft - the float chamber is different between these configurations
But it's mostly fuel injection and ECU these days which is far superior to carburatorsLast edited by ericcs; 14-09-2014, 12:40 PM.
