i didnt align the engine to TDC before ripping off the cam belt, am i stuffed? how do i recover from this before putting on the new cam belt and hoping the engine doesnt go boom.
ANY HELP APPRECIATED!
VW: it aint just a car, its a way of life There are few things more satisfying in life than finding a solution to a problem and implementing it
Just stick some chop sticks or skewers down the spark plug holes and figure out where the pistons are. You can also remove the valve cover and splash tray and figure out which valves are open, and how far.
The compression is low enough to offer you a fair bit of lee-way, so don't stress too much - just turn things over gently.
One you've figured the position of everything - and double checked it - you can get #1 at TDC and align the other pulleys from there. Easy
cos i didnt RTFM but we learn from our mistakes rite
i've got the intermediate shaft lined up, the valves in the right position (cylinder 1's valves are both closed) now i just have to figure out where the pistons are. i may employ some help to double check however
TDC is piston 1 at the top of the compression stroke isnt it?!
The 8 valve can be an awkward one because of the intermediate shaft but there is a notch in the distributor body and with everything lined up the rotor arm should be pointing to the notch.
You can get the crank to TDC by temporarily sticking the bottom cover back on and the bottom pulley and lining up the notch with the mark.
There is also a spot on the cam pulley which IIRC goes level with the top of the cylinder head, the gasket face for the cam cover.
The crankshaft and intermediate shaft dots should come as close together as possible.
The dot on the camshaft pulley lines up with the top front edge of the head (The gasket sealing surface).
Take the cap off the dissy. There is a mark on the top edge of the distributor body that indicates firing posn for no1 cylinder. The rotor should be pointing roughly at it if everything is OK.
Use something down the spark plug hole to find TDC.
The mark on the flywheel should also be visible if you've got it right. (Unless some tool has put your flywheel upside down like mine!)
Take your time and think about it!
Pete
can i ask a massive favour of you Pete?!
can you come and help me do this? there may be a 6 pack of your fav beer in it
