Hey guys I've been trying to play around with this for a few days now and It seems like I need some advise!
I've brought a bosh GT40 with no resistor as the diesel loom doesn't need a resistor, straight 12v, and I've basically brought a new points mechinism, rotor button and distruibter cap to ensure it will work more effectively.
I've wired up the coil (from ignition to +, - to dizzy) and everytime I cranked it the motor won't start! I've made sure its TDC and first piston is on top and I've checked the coil if there is 12v going into it and there is, it is and also sending out 12 v to the distruibter but when I take out the 1st spark plug lead and crank to see if there's any spark it's just dead! Doesn't sent out spark at all! I've also ran a temporarily wire from starter to + on ignition coil, earth to - and still won't spark up!
